In the " Slack Integration Guide" (https://support.pagerduty.com/docs/slack-integration-guide), under “Create a Slack Channel from a PagerDuty Incident” heading, it says
- Select from the following options:
- Select existing Slack channel for this incident : Search and select an existing Slack channel .
- Create a new Slack channel for this incident : You may use the auto-populated incident Slack channel title, or enter a new one. You may also select whether you would like the channel to be Public or Private .
- Click Set Channel .
Is it possible for us to set our own slack channel naming convention to display here?
I can not find a way to do so.
So I am opening this feature request.
